Rear deck/trunk divider. help
Post by MallyMal S-3 on Mon Jul 13, 2009 10:20 am
anyone know where i can find the pad and card board that goes above the rear deck panel/ trunk divider. my panel is fine but the padding looks like a rabid chipmunk went at it affraid
MallyMal S-3
Street Cred: 0
View user profile
Re: Rear deck/trunk divider. help
Post by 74Malibu383 on Mon Jul 13, 2009 10:31 am
OPGI:
RSS5800: 73-77 Shelf
1R5600: 73-77 Shelf w/jute (padding)
You should probably go to thier website and order a free catalog. They're making more stuff every year for these cars.
Street Cred: 20
View user profile
Post by MallyMal S-3 on Mon Jul 13, 2009 11:26 am
you are definately my go to guy. thank you thank you thank you. ok and if i going to replace the dash should i try to part it from another car or just simply get a dash cap??
MallyMal S-3
Street Cred: 0
View user profile
Post by 74Malibu383 on Mon Jul 13, 2009 11:39 am
Good luck finding an unmolested dash for these cars. I tried and tried, but was unsuccessful. I found one on eBay that went for over $1,200 at auction's end.
I purchased and tried to install one of the dash caps, but the vent cut-outs didn't line up perfectly on mine. I've seen some decent installs, but they're never perfect. You can always see a little bit of the factory dash around the bottom corners. Since my dash was literally destroyed, I removed it and sent it to Just Dashes. They specialize in completely removing the original vinyl and padding and rebuild it by hand. They then put it into the Thermo Vacuum Forming matching and vacuum form the new vinyl just like it was done at the factory. The results are absolutely AMAZING, but pricy. Each dash requires a custom quote, but you're looking at about $800 or so.
I guess it's all a matter of how far you want to go with the car. I was going to just do the dash cap, but I got so carried away with the rest of it, I just couldn't see settling when it came to the dash.
Street Cred: 20
View user profile
Post by MallyMal S-3 on Mon Jul 13, 2009 12:02 pm
mm we'll see. i'll purchase the dash cap now and pray it fits to my likings. thanks man.
MallyMal S-3
Street Cred: 0
View user profile
Post by coreys73chevelle on Mon Jul 13, 2009 4:04 pm
74Malibu383 wrote:OPGI:
yep they have them
coreys73chevelle
Street Cred: 8
View user profile
