Speedo Not Working
Speedo Not Working
My speedometer is not working. I know the cable is connected on the trans and is connected to the rear of the speedo. I don't know if the speedo worked prior to to installing it since I bought the speedo used. Its the round speedo and its out of a '73. Do speedos go bad? Is it best to replace the cable and go from there? The trans was rebuilt so I would think the trans portion should be good.
Hawk03- G3GM Enthusiast
Re: Speedo Not Working
Disconnect the cable at the tranny and spin it by hand or with a drill while someone watches the Speedo. Seriously doubt the problem is with the Speedo Bullet/Gear combo in the tranny...unless someone forgot to put them back in there when it was rebuilt. If you can narrow it down to the Speedo needing replaced, I can try and find a good one this weekend when I'm out pulling parts for other members. If I remember correctly, the condition of the face isn't important as you'll be using white-faced gauge decals anyway?
As a quick check, you could take it off the trans, Chuck it up in a power drill, and run the drill to see if the needle moves. At least you can see if it's a problem in the trans or not.
Edit : looks like he beat me to it
clanceman427- G3GM Enthusiast
Thanks Mcarlo77, I knew there was a way to test it but work has killed my brain the last couple of weeks so my thought process isn't the best right now.
That would be great if you could pick a speedo up if you find one this weekend. Might as well have one on hand just in case. Could you also see if there is a small round fuel gauge too? That doesn't work either. Correct, face condition is not important since I have the white faces to go over them. Much appreciated!
Today at 12:36 am by Limey SE
