4 door Guys chime in Please
2 posters
ok 4 door Guys I am needing a floor pan measurement I am buying carpet and the 4 door (for what ever reason) carpet is cheaper than the 2 door carpet by 41 Dollars cheaper CONFUSED HUH ?
Anyways can a anyone or a 4 door Owner chime in In asap if they are same size Carpets, I know wheel base is Longer but are the floorpans longer also and if so why could not the 4 door carpet work on a 2 door
Re: 4 door Guys chime in Please
If I had to guess, I'd say the the carpet is cut differently in the location of the B pillar. Doesn't really explain why its cheaper though...
Talked to 2 four door guys and 3 two door guy that used the 4 door carpet and will work with coupe its a 1/2" longer on each side so thats not a bad thing I would rather have excess to trim than be too short
» Door question for the guys with 76 and 77 cars.
» WANTED - 4 Door/Wagon lower Door Seals
» WANTED - 73 4 door/wagon upper door panels
» '77 Cutlass 442- NoCal
» Dash woodgrain
» Hood Latch
» OOOPS I did it again.
