does anyone know???
does anyone know???
if there is a direct fit TVcable for a my 75 monte carlo that has changed over to a 700r4
alive 75- G3GM Member
Re: does anyone know???
If you are still running a q-jet I would look into a 1980's Caprice that came with a TH700-R4 and a q-jet, that should fit.
Iggy- G3GM Member
TW Monte likes this post
I used one from an 87 Caprice to fit my 73 Monte with a qjet and 200-4r trans swap
TW Monte- G3GM Member
I used one from an 87 Caprice to fit my 73 Monte with a qjet and 200-4r trans swap. I was also able to grab an oem cable bracket off of an 88 Delta 88 that had qjet & 200-4r.
Do you already have a driveshaft for your set-up?
impalamonte- G3GM Enthusiast
» 2" rear lowering springs
» Direct fit radiator
» hot rod article
» 882 Heads from 74 Corvette
» Fuel gauge
