SBC 355
SBC 355
what exactly is a 355? is it just a sligthly bored 350? just curious what the bore/stroke is
Re: SBC 355
i think thats all it is is a bored 350 but idk the bore size
1973chevelle- G3GM Member
Re: SBC 355
a 355 is a stock 350 taken .030" over the standard bore of a normal 350 mine is a 355
Re: SBC 355
ohh ok..how much does that extra bore help? i dont know a lot about boring and such, i havent gotten that far in my learning to know how much it helps...i mean an extra 5 inches is an extra 5 inches so i know its good for something.
Re: SBC 355
its not an extra 5" per say just increase the standard bore by .030" that's only 30 thousandth of an inch suppose to increase horsepower
Re: SBC 355
Really not gonna make a noticeable difference. Mostly it comes from a necessity rather than a power increase method. When you tear down an old motor & notice a ridge at the top or scoring in the cylinder, it becomes necessary to bore out the cylinders. Pretty much as simple as that. Here's a formula to follow:
Displacement = (bore) x (bore) x (stroke) x (# of cylinders) x (.7854)
Re: SBC 355
I have a 355ci roller. you get a 350ci and bore it .030 over no difference of stroke or internals. it isnt a 383 stroker until you get a 400ci crank and flywheel or flexplate and usually you change the rods to 6" rods but you dont always have to
Re: SBC 355
Are you forgeting the diff size pistons you HAVE to put in ??coreys73chevelle wrote: .030 over no difference of stroke or internals.
Re: SBC 355
haha yea. ull need .030 overbore pistons they will be under 350ci and say .030overbore
Re: SBC 355
mine just said..... + .030"
Re: SBC 355
i mean online and in magazines. my pistons also say +.030"
Re: SBC 355
hey you get that yet ??
Re: SBC 355
coreys73chevelle wrote:I have a 355ci roller. you get a 350ci and bore it .030 over no difference of stroke or internals. it isnt a 383 stroker until you get a 400ci crank and flywheel or flexplate and usually you change the rods to 6" rods but you dont always have to
Stick with 5.7" rods on a 383. I know 6" rods are an option, but then you get into more block clearances that need to be made, small base circle cams, & also the pin will be higher into the piston. I believe it actually cuts into the bottom ring land. Someone want to double check me on this one?
Re: SBC 355
thats what id like to build eventually...im gonna go with my 350 in the mean time and add cam heads intake and headers, do my interior, suspesnsion, rebuild the rear end, add a posi, new trans, and then id like to build a 383 with a weiand blower...should be pretty mean.
Re: SBC 355
edelbrock 2101 4 barrel manifold here for sale also if you want that as well travis
Re: SBC 355
yeah man i saw that, i think i might have to get that from you as well if you still have it around in a month or two. thats the manifold i want
Re: SBC 355
well pm me an offer and i can send both, the wheel and this at once
Re: SBC 355
i wish dude...i just had to drop almost my whole paycheck for this week on new suspension bushings, control arms, shocks, etc...but ill be able to take it off of your hands here in a couple weeks.
Re: SBC 355
ok bro hold it till after the first for ya
Re: SBC 355
thanks man i appreciate it...any chance you know how much itll be shipped?
Re: SBC 355
alright...so the things good? its not corroded inside or anything?
Re: SBC 355
no sir you wont be disappointed
Re: SBC 355
sounds good to me man...if you still got it around when i get the money ill hit you up for that as well.
