'73 SS Striping
'73 SS Striping Empty '73 SS Striping
Post by Joe73 Tue Feb 21, 2012 9:46 am
I've searched hi and lo and cannot find my striping dimensions from my '73 before I redid her. I had them all measured perfectly. Anyone have a copy of the dimensions. Hopefully next winter I'll be restoring the new frame and swapping the body over. Then finally putting the side stripes back on and probably clearcoating the whole thing. Any help would be appreciated.
Thanks alot guys!!
'73 SS Striping Empty Re: '73 SS Striping
Post by Trbulnc Wed Feb 22, 2012 2:48 pm
I have pics I took with a tape measure laid on the stripes. If nobody has actual dimensions I can post them up
Trbulnc
Post by 77mali Wed Feb 22, 2012 2:55 pm
It would be great to post that info (for those of us researching the same) Very Happy
Post by Joe73 Wed Feb 22, 2012 2:56 pm
Yes, that would be great!! PM sent!
Post by Trbulnc Fri Feb 24, 2012 9:37 pm
Sorry so late
'73 SS Striping 3a451b11
'73 SS Striping A2721453
'73 SS Striping Beae6ad1
'73 SS Striping Bfb1e457
'73 SS Striping 05d6cd93
'73 SS Striping 6a379871
Trbulnc
Post by 77mali Fri Feb 24, 2012 9:43 pm
Thanks for posting that info!
Post by Trbulnc Fri Feb 24, 2012 10:02 pm
Hope it helps. Someone might have a sheet with actual dims I haven't seen.
Trbulnc
Post by Limey SE Fri Feb 24, 2012 10:37 pm
That looks alot like the Laguna striping as well ?? I have them pics if needed ??
Post by Joe73 Sat Feb 25, 2012 12:45 am
Yes, those pics are good. Quick questions. Is the first pic of the bottom of the door? Or the quarter panel? Does the quarter panel wide bottom stripe taper smaller from the well to the bumper end like by the front bumper? Thanks for posting.
Limey, if I remember correctly, the laguna striping is the same til about '76 when they moved the stripe up higher on the door. Do you have any dimensions and or pics to share?
Thanks
Post by Limey SE Sat Feb 25, 2012 1:38 pm
i knew I had them some where LOL Thanks to Doc Larry for the Pic !!
'73 SS Striping 84b6c328
Post by Limey SE Sat Feb 25, 2012 1:42 pm
and striping for 73 SS and 74 S3 is almost identical just have to adjust the thickness (taper it down some) to meet the Impact rub strip correctly, after that it does change and I have dimensions saved as well !!
Post by 77mali Sat Feb 25, 2012 5:36 pm
Dang that's a great diagram!
Post by Joe73 Sat Feb 25, 2012 7:08 pm
77mali wrote:Dang that's a great diagram!
X2. Great work Limey. Nice diagram. Cant wait to put mine back on. Funny thing I see all the time. When I got my SS in '82, all the other SS's Ive seen all had the satin black tail panel. Mine as well. I never see that anymore on the '73's. Wonder why.
