help
help
Have 2 different seal plates what is the right one and whatis the other for
Re: help
Yep...top one is correct. Be advised that there is a designated right and left. Not a clue what the bottom one is for...
Re: help
Cool thanks that's kinda what I thought but wasn't sure. Amazing how many things you take for granted until you get a car that has some assembly required.will have more bits to ask about for interior.since I had a butt load of little trim pcs
Re: help
Top for sure. If you take some metal polish, and one of those buffing balls, they will shine up pretty nice!
JiMi_DRiX- G3GM Enthusiast
Re: help
I will thanks. I might have to reuse my sail panels cause ones in trunk I think are cutlass or monte Carlo since there is no opening for the light between the door and opera window
Re: help
Not all Buicks had those "B" pillar courtesy lights...so, they could very well be off a Century/Regal. I've documented most of the sail panel numbers off various "A" bodies, so if you'd like, send me the part number off the backs and I'll help you identify them. Maybe you can unload them on this site...or, e-Bay.
Re: help
They should fit in Cutlass' and Monte Carlo's, right Steve? Maybe Grand Prix also.
Re: help
Monte Carlo and G.P.'s are each unique and don't cross over to any other "A" body.
Re: help
Reason I say cutlass is there is an upper door panel that says brougham
Re: help
Here are some numbers of parts
9738830 & 9738831 r & l hand gm canada. ( sail panels)
9684317
988677
Also have not one but 2 chrome strips that run along top of the passenger door that are extra
9684317
988677
Re: help
Interior has red and white parts now then if I use sail panels will be red white and blue and then other parts around door are laying there are black lol
Re: help
Sail panels are for Monte Carlo only.
Can't find any reference in my notes regarding the other two part numbers. Maybe send a pic of each part so I know what you've got?
Re: help
One is the plastic trim on the top of rear window
Re: help
And other is upper seat belt cover and (I call it a flap lol)
Re: help
Wondered if that last number you gave wasn't supposed to be 9892677...which would be the rear window headliner trim. That will fit your car.
I haven't documented the shoulder belt retractor covers as they all will fit; although there are a couple slightly different shapes out there.
Re: help
Well I have monte sail panels I can't use and a spare rear window trim pc . Are those door chromes with the rubber worth much? And what sail panels interchange? Noticed monte has gasket on inside by the glass and the one in car doesn't that normal?
Re: help
If the upper door window wipers are in good condition, they're worth something to someone. But, usually the rubber wiper part has splits in it and the black vinyl coating along the channel is dried out and cracked/peeling. If that's the case, they are just like everyone else's. Repros go for around $185/pr last I looked.
Monte sail panels are unique to that model only.
Re: help
Re: help
Looks like you're in need of this swivel trunk lock cover! I pulled this for another guy and he just disappeared without following through.
» '77 Cutlass 442- NoCal
» Dash woodgrain
» Hood Latch
» OOOPS I did it again.
