Rear Sway Bar Mount
SSTOOLMAN
G3GM :: Classifieds :: Wanted
Rear Sway Bar Mount
Hey Guys, Does any one have the factory mounting insert/bracket that goes in to the lower rear control arms
the sway bar attaches to? I broke the bolts off one of mine while removing my sway bar. I drilled them out and retapped them but I don't think the threads are substantial enough hold. Its a 73 SS if that makes a difference.
Thanks in advance!
Thanks in advance!
SSTOOLMAN- Donating Member
Re: Rear Sway Bar Mount
No difference if its an SS or monte or cutlass, etc. If you broke one of the vertical bolts that hold the bar onto the insert, put a nut and lock washer on rear side. If you broke of the side bolts, Id drill it out to fit a grade 8 bolt and just tack a short sleeve in the center of the "U". That way you can crank down on the bolts.
Quick fix.
Quick fix.
Tim I sent message on book of face LOL Ivan Toledo has a set
You can order that insert new. Limey knows the GM part number and how to order it
clanceman427- G3GM Enthusiast
clanceman427 wrote:You can order that insert new. Limey knows the GM part number and how to order it
And order the bolts with it. Ours are discontinued. The ones you can order now use metric bolts.
GM PARTS DIRECT discontinued that from there site Its Unavailable I found a set for him from a Friend in Florida But with everyone being out of work the price didn't work for Him...... I even offered when I get off my crutches I would give him one that I have when I switch to my Boxed arms ( they wont use the inserts ) Said no ...So I guess he is gonna try and make his work
I sent him a PM. I have a set of the rear control arms complete with poly graphite bushings . I removed the set over the Christmas holidays.
I did not apply a price in the PM ...but offered sending a picture if interested.
He's has not responded.
Don't know if he just decided to go a completely different direction.
Mark
Mark
impalamonte- G3GM Enthusiast
Maybe I am not sure, He may have just decided to use the ones he had also with the Bolt suggestion Like Joe73 Mentioned......
Or even use a cut off wheel and cut the nuts off. Then tack weld new ones on. Very easy to correct this issue.
This may be a good opportunity to stick a set of boxed control arms on the car...which I may or may not have...ha.
brownbomber77- G3GM Member
» 1.25 front sway bar with 1.5 rear sway bar?
» Summit- Rear Sway bar
Today at 10:24 am by zucchi
Yesterday at 7:41 pm by Joe73
» 1973 Chevelle SS 1 Family
