Light Bulb Sizes
G3GM :: G3 Tech :: Electrical
Light Bulb Sizes
Hey. I am about to order all new LED lights for my car. So, if someone could chime in with the correct sizes for all the lights, including the license plate lights, I would greatly appreciate it. I have purchased the headlights, the Halogen version, already. I am re-wiring the entire car right now and I am going to add a relay kit for those. And, by the way, my car is a 1976 Laguna. Thanks.
Ok, here is what I have found so far. I am using Rock Auto as my source right now.
Front blinker-1157NALL Amber 2ea
Rear blinker-1157LL Clear 2ea
Tail lights-1157 2ea
Side markers-194 4ea
License plate light-194 and 168 2ea My sockets seem smaller than the side marker lights
Does all that seem correct? Cheers.
- Street Cred : 19
Re: Light Bulb Sizes
Those should be the correct sizes. I have 1157 clear in my front and rear tail/brake lights. I have amber lenses in the front, not sure what color Lagunas are. I think the reverse lights are clear 1156. The license plate is 168 but the only difference between a 194 vs 168 is the 168 is supposed to be brighter. Not sure if it matters since LEDs are brighter anyway, below is a picture of my license plate lights. I think you will also need a grounded turn signal flasher, the below link is the one I have.
https://www.amazon.com/CEC-Industries-EF32RL-Flasher/dp/B00JXLH7CG
Hawk03- G3GM Enthusiast
Hey, thanks for the input. Lagunas have a clear lens in the front. I have the little resistors and I was about to wire those in. I was thinking that the reverse lights should be the 1156. I am going to place my order with Jegs in the morning. Cheers
- Street Cred : 19
I forgot, I don't have LEDs in my front turn/parking lights. The rest of my lights have LEDs and I did not wire resisters and they work just fine. I think most of the new LEDs should be a direct install. I ordered mine through Amazon and Superbrightled.com.
REVINKEVIN wrote:Hey, thanks for the input. Lagunas have a clear lens in the front. I have the little resistors and I was about to wire those in. I was thinking that the reverse lights should be the 1156. I am going to place my order with Jegs in the morning. Cheers
If you buy from superbrightleds.com, they will have the equivalents for all the lights you need, and the resistors are already built in, so you do not need to add anything yourself. Plug-n-play.
Today at 12:47 pm by JCervantes10
» 1973 Chevelle SS 1 Family
