Bought a truck
+7
laguna454/4spd
Admin
coreys73chevelle
11 posters
Page 3 of 3 • 1, 2, 3
Re: Bought a truck
Here's some of those stock 4x4 wheels for $100.
http://joplin.craigslist.org/pts/2001864598.html
This guy also has a set for $75. Looks like he might have your oil pan for $20, but it doesn't say which motor. Give him a ring & find out.
http://joplin.craigslist.org/pts/1961855446.html
Re: Bought a truck
I called that guy, the oil pan is a stock 305 v8 oil pan.
BlackChevelleSS- Management
Re: Bought a truck
i always liked these trucks hope you get it lined out nice truck
laguna454/4spd- G3GM Member
Re: Bought a truck
BlackChevelleSS wrote:I called that guy, the oil pan is a stock 305 v8 oil pan.
That's misleading as hell.
Re: Bought a truck
I almost bought a white one about a year ago. 4.3 s10's are great, if you have ever driven a sorry A$$ 2.8 truck, you will think the 4.3 is a v8..lol My old 4.3 tbi blazer with a dynomax catback.
https://www.youtube.com/watch?v=EaJl1uuPmyM
Jim_Rockford- G3GM Member
Re: Bought a truck
Had an 83 with a carbed 2.8, auto & 3.73 gears, Horribly slow. Never own another one I hated it so much.
A 95 with a 2.2, stick, 4.10 gears.... peppy for a 4 cylinder, still slow though. Twice as fast as the 83.
A 93 with the CPI, auto, 3.42 gears.... Lots of usable power.
& now an 88 with a 2.8 TBI, auto, 3.08 gears.... surprisingly not as bad as I thought it would be, but still slow until you hit highway speeds.
Re: Bought a truck
had a 91 blazer 4x4 with 4.3 wacked of the cat raptor muffler (exhaust was straight pipe from y back ended where frame kicks up for rearend) advanced the timing and little sob was faster better mileage and people thought it was a v8 had 87 4x2 blazer with 2.8 and was a decent little truck
Re: Bought a truck
Engine is at the machine shop geting vatted, honed, cam bearings, freeze plugs, and balance shaft bearings. Heads are getting checked as well as the rods. Might do a valve job havent decided yet.
Gonna be fresh motor when I get done, new bearings, rings, oil pump...
Re: Bought a truck
It should last you a long time with all of that refreshing. Longer than the Screamin' GEO for sure.
Might as well at least pocket port those heads while you got it tore apart though.
Re: Bought a truck
heres some pics of the engine in it
Changing the fuel pump for good measure, ended up all the rubber had turned to gummy sticky stuff. The Baja has a solid steel skidplate around the tank, it was much easier to remove the bed.
Got a roll pan for it, have some plans for a rear bumper.
Re: Bought a truck
Looks good man, I seen a black one cruising down the road Sunday....
Re: Bought a truck
Thanks, Ive been holding off on doing much more work than that because I still dont have the title. Hopefully within a week or two ill have it.
Re: Bought a truck
its finally tagged, titled and insured. been driving it alot.
these are 33s that im gonna try and get to fit
Re: Bought a truck
I saw one of these today! First time I have even ween one out anywhere!
It was a POS though.
Re: Bought a truck
S10's and S10 Blazers are everywhere in Indiana. It's pretty funny getting looks because I have a Blazer that doesn't have any rust holes in it.
IndyG3- G3GM Enthusiast
» I just bought some pee
» what kind of car would you have bought if you were 12 again?
» bought another set of wheels
» Window louvers
» 1973 Chevelle SS 1 Family
