Interior Water Leak...
Hey Everyone, well it seems that the oil leak stopped now it's time to find the water leak. I know that the windshield leaks but it seems like too much water on the passenger side floor for it to be that. I took off the plastic vents on the firewall earlier today and reached inside and found a ton of what appears to be fur inside of the firewall. I know that inside there si suppose to be a vent tube of some sorts, anyone have experience with these getting cologged and water leaking into the passenger compartment. Oh I forgot it's a 73 Pontiac Grand Prix
Also I have never removed the console in one of these so anyone care to share as to the easiest way to remove the shifter knob to get the floor console over it? Have to pull the carpet, causing too much humidity in the car when it rains and I guess that will help me find the leak. Any help would be appreciated. Thanks
mrimax- G3GM Newbie
- Street Cred: 0
Re: Interior Water Leak...
Some times a bad heater core will leak water and its always on that side as i understand it. But if you know that windsheild is bad def should get that out of the way first. In my opion thats what i would do.
Jedediah- G3GM Member
- Street Cred: 4
I would say heater core leak. Not many other places the water could come from other than that. Does the water feel slick or smell of antifreeze?
Laguna Budman- G3GM Member
- Street Cred: 4
As for removing that floor console, you'll need to first pry off the cap on top of the shifter. Use a very small screwdriver or some such thing to get under the edge and pry it straight up and off. There are two notches 180 degrees from each other for use in prying up on it. Once that is off, look down inside the shifter knob and you'll notice a "c" clip at the bottom. Get that off and then pull straight up on the knob. They can sometimes be stubborn after so many years, so carefully work it off without damaging the knob.
Mcarlo77- 2012 Donating Member
- Street Cred: 17
Maybe the heater box seal it self .Also could be the cowl maybe is backed up with old leaves. Take that screen off right under the wiper arms and reach around in there maybe stick a shop vac in there and see what comes out. There is a drain in there on top under the fender right near the door try cleaning it out with a coat hangar then flushing with a hose or air compressor.Both sides have the drain.Neat car too !
ant7377- G3GM Senior Member
- Street Cred: 12
A body's are notorious for leaks around the windshield, opera windows & back-glass. I have mine all torn apart and had the heater core out for refurbishment. If it was the heater core you'd certainly smell the coolant. If there is no smell then chances are it's the windshield. It is also possible that it's getting in through the weatherstripping (although unlikely, unless it's in really bad shape). When it rains heavy and it soaks through my car cover I get it on the drivers side floor board. I'm getting both sealed @ the glass shop when she can drive and am saving the carpet and interior for last.
77mali- 2012 Donating Member
- Street Cred: 14
Above the heater box assembly, on my '75 Elco, there's a plenum with a curved top, which is sealed to the fire wall. I believe it's for the defroster ducts. Anyway, it had been leaking at that seal for along time, and when I gutted the interior for sand blasting, I saw where the leak had caused rusted pin holes in the lower right firewall, and likely was the source of water that rusted the right front floor..
You may want to remove the entire heater/defroster assembly, if you think it could be coming through the firewall. Not a fun job, but sometimes necessary.
pila- 2012 Donating Member
- Street Cred: 17
Not The heater core, only happens when it rains. Should have said that earlier. Pulled the screen off earlier today and found the remnants of the hood liner in there. Looked like a rat crawled up in there and died. Gonna try tmorrow to get a vac in there and try to clean it all out then look to see if I can clean out the drain. Thanks for the input......
mrimax- G3GM Newbie
- Street Cred: 0
Found One Of The Culprits After Removing The Carpet In Front
Not looking to replace the firewall so it looks like por 15 and whatever I can use to seal this and any others up. Not looking forward to it. Also found the door weatherstripping needs replacing. Hopefully that will fix the problems.....
mrimax- G3GM Newbie
- Street Cred: 0
Welding on the firewall isn't a good option either. My way in that situation would be to cut the bad areas out, and pop-rivet some sheet metal over that area. A few coats of spray-on under coating inside & out would likely seal it OK. On the inside, a layer or two of waxed paper from the wife's kitchen would seal the undercoating from the carpet padding.
- Street Cred: 17
Well I have the drivers side out and I can't see anymore holes like the one above, I'm going to hit the car wash tomorrow to see what and where the rest of the leaks are coming from. At least for now it's not as bad as my Challenger was. Had to pay to have the whole firewall replaced.
Keeping my fingers crossed that this will resolve the issues.........
mrimax- G3GM Newbie
- Street Cred: 0
This was a real problem in my brother in law's Monte Carlo.Kinda hard to fix. Look at the drivers side kinda above the fuse box see how it is there.
- Street Cred: 12
Replaced the windshield Friday, Had a company come out, pull the windshield and then leave me to fix the holes that were found. Found three that were just under the base of the windshield about the size of a quarter each. Sealed them and then patched them. It appeared that I had them all fixed. No holes in the actual glass channel around the windshield which was a good point.
Called the guy back out and had him look to see if he could see any other holes. He couldn't find any as well. Replaced the windshield and was happy with the whole process and cost. $225.00 for them to do it. Not bad since they actually left and let me fix the holes. Took the car to the car wash and no leaks, soaked it pretty good around the windshield so it all appeared to be good.
It poured here last night and I thought since it didn't leak at the car wash that it was all good so I didn't cover it. This morning I once again had a puddle in the passenger front seat. Not as bad as it was but still water on the floor. Was going to be putting the carpets in today but now I'm at a standstill. I took the glove box out and crawled up under the dash as well and I'm not finding anymore holes but the water is coming from somewhere, I'm getting frustrated with this, I guess I'll just have to keep looking. Sorry for the vent....................
mrimax- G3GM Newbie
- Street Cred: 0
My old 73 use to leak on the passenger side somewhere above where the kick panel met the door panel. I could follow the water, but never find where it came in. IT was just a trickle, but after a long rain it was bad. The weather stripping was new and I never figured it out..
JiMi_DRiX- G3GM Member
- Street Cred: 1
Could be the flap for the recirc mode seal leaking a bit.
Mine leaks in the trunk, from the rear window, and also a quarter window leaks a bit.
texan01- G3GM Member
- Street Cred: 5
Similar topics» Is your interior what the Discovery Channel is looking for?
» GSI with oil leak
» Transmission oil seal leak
» water pump oil seal.
» Lidl doing a Water Resistant HD Camcorder
» GSI with oil leak
» 73 CHEVELLE SS PICS
» 75 cutlass
» Just some pics
» Old Photo Tow Truck
» NO...NO...NO...
» ~~Introduce Yourself~~
» 76 S3 in Franklin Indiana
