trouble removing clock adjustment knob
WyldeBill66
I got the threaded sleeve off the shaft with a tiny flathead screwdriver but the knob remains stuck in place.I tried prying it loose with a small prybar but no luck.Are these things glued on or just a tight fit?I don't want to damage my clock,any suggestions? Thanks.
fishhead- G3GM Member
Re: trouble removing clock adjustment knob
If you have some penetrating oil handy, like Liquid Wrench etc. a drop of it on there to soak for a bit might help. Some masking tape on the lense to protect it, long nose pliars on the stem after you pull it out a bit. Pry on the pliars against the knob with a screw driver & not against the clock mechanism. Had to do that some years ago..
I'm glad I asked,it's best to hear from someone who's been there.Does anyone have a REALLY TINY gear puller? Thanks for the help friend,I'll take your advice.
fishhead wrote:I'm glad I asked,it's best to hear from someone who's been there.Does anyone have a REALLY TINY gear puller? Thanks for the help friend,I'll take your advice.
little needle nose has to grab the stem. it will come off WE promise
1973montec- Donating Member
Yup,got needle noses.Forceps,hemostats,clamp....
Paging Dr. Howard, Dr. Fein, Dr. Howard....
LOL
LOL
Or like mine, it just pulled out, stem and all...
WyldeBill66- G3GM Member
Ouch....sorry to hear that bro.Mine is soaking in penetrating lube overnight before surgery tomorrow.
I see that some clocks are being converted to new tech digital style, that actually keep time !!. Mine would speed up in summer. and lose time in winter. I have triple gauges in the clock openings on both cars now.
Did you get that clock stem off? I've got an extra if you mess yours up.
Thanks! I've been real busy lately and haven't been back to it,but maybe the extra-long soak will be a good thing.Once I pull the little knob off I can remove the dash bezel so I can clean the gauge faces,I forgot about G3 chevelles having 9 gazillion screws.I found a hood for my 73 but will have to ask the guy to deliver it for extra scratch since my buddy with a truck let me down.I snagged a 400 2-bolt block recently for one of my engine builds and will be sending it to the local machinist soon.I've got WAY more plans than I will ever have money but I guess that's what gets me out of bed every day.I'll let you know if I that knob gets FUBAR and we can make a deal.
Hooray!! After a very long period of constant penelube injections the knob has FINALLY cooperated!No damage.Yeesss!! All it required was constant,gentle tugging with pliers every few days.
Nice glad to hear it all worked out to the good
» 1973 Chevelle SS 1 Family
