Trnsmission cooler line..
Anyone remember which of the lines to the radiator is the return line to the trans ? I have a cooler to add to my Elco.
Not sure if it's the bottom one.....
Re: Trnsmission cooler line..
It's more important you get the trans ones right..
Upper is return in
Lower is to cooler
I'm pretty sure the top in the rad is the return.
I have an additional cooler so mines a mess of lines and fittings (all AN stuff)
Upper is return in
Lower is to cooler
If the car is set up right, the lower line on the radiator tank is the inlet, and the upper is the return to the trans. The most efficient heat exchanger is a counter flow heat exchanger. So since the engine coolant is moving top to bottom, you want the trans fluid to move bottom to top.
Today at 12:45 pm by Limey SE
Today at 11:44 am by mikidymac
Today at 11:34 am by mikidymac
Today at 10:48 am by 76Chevelle2Tone
Yesterday at 6:44 pm by Limey SE
Sun Apr 28, 2024 11:04 am by 454fourspeedss
Sat Apr 27, 2024 5:29 pm by Limey SE
Sat Apr 27, 2024 9:25 am by bracketchev1221
Wed Apr 24, 2024 6:37 pm by 76 Malibu
Wed Apr 24, 2024 2:18 am by relic7680
