Door glass pictures
Door glass pictures  Empty Door glass pictures
Post by Trbulnc Fri Dec 23, 2016 9:01 pm
Anyone have any pics of their door glass mounted or a page from service manual showing the mounting points? After 3 years my memory is foggy and the pics I took were not great. Have the track in with the glass installed but the rest is fuzzy....like the two holes in the front of the glass. It still is really sloppy.
Thanks.
Trbulnc
Door glass pictures  Empty Re: Door glass pictures
Post by Joe73 Fri Dec 23, 2016 9:39 pm
Like this ?? If you need a bigger copy, pm me your email and I'll send you the pic. Happy Holidays.
Door glass pictures  Door_w10
Post by tropdeprojet Fri Dec 23, 2016 9:50 pm
Wow, this is great! The glass was removed since long time me to.
tropdeprojet
tropdeprojet
Post by Joe73 Fri Dec 23, 2016 10:06 pm
Any other pics you guys need just ask.
Post by Trbulnc Sat Dec 24, 2016 1:18 am
Perfect. Huge help. Merry Christmas!!
Trbulnc
Post by 73ss Mon Jun 12, 2017 9:48 pm
I found this pic helpful. I couldn't shut the door over the week-end. It ended up being the anti-rattle/rubber rod retainer on rod #15 tore and jammed up the whole works. (The thing right below 4) Now I have a rattle. I quieted it down some with a loose zip tie. Also, I see 3 window felt brackets in the diagram #11. This was talked about in another thread. I think all of us have ever seen 2. Mine has the 2 outers. Maybe all 3 were on power window set-ups? I took the felts out and cleaned them while I was in there. Re-glued and Sprayed some dry lube on them.
Post by Mcarlo77 Tue Jun 13, 2017 7:19 pm
73ss wrote: Also, I see 3 window felt brackets in the diagram #11. This was talked about in another thread. I think all of us have ever seen 2. Mine has the 2 outers. Maybe all 3 were on power window set-ups? I took the felts out and cleaned them while I was in there. Re-glued and Sprayed some dry lube on them.
Right after I posted on that other thread, I was pulling a door glass from a '75 El Camino. Lo and behold, there were three of these brackets. No power windows, either. I don't know what dictated the use of 2 or 3...
Post by 73ss Wed Jun 14, 2017 5:24 pm
Also noticed the top door panel on my car has a 3rd spot to snap into the bracket.
