Speed Bleeders
Speed Bleeders
Seems I have a leak at the rear of the master cylinder (between the m/c and booster) on the Laguna, so I'm guessing the rear seal is the culprit...leading to the fun job of swapping in a new m/c and bleeding the system, again. Sucks because I just went thru the whole brake system about 5 yrs ago on this car. Anyway, I've always relied on the tried and true method of a helper pumping the brakes while I opened/closed the bleeder screw. But, it's a hassle trying to corral someone to help. I bought a MightyVac pump kit a few years ago, but it never seemed to work efficiently for me. Tried gravity bleed method and that didn't work. Now, I'm considering installing some solo bleeders so I don't have to rely on a helper. Anyone using these? Any particular brand better than others? Seems I read at one time that they can be problematic years after installation, but can't remember the details. Can only assume it had something to do with the check ball sticking in the open position?
- Street Cred : 71
Re: Speed Bleeders
I have speed bleeders on the front brakes but not the rear drums. No problems for me
JF74chevelle- G3GM Member
Re: Speed Bleeders
I have used them before on several cars for the same reasons your are considering them. They worked well for me. The only issue is the thread sealant can wear off and allow air in through the threads.
76 Malibu- G3GM Member
Re: Speed Bleeders
Maybe use em to bleed initially then swap for normal ones when done. I hate dealing with that part of the system.
Re: Speed Bleeders
Maybe it was the thread sealant issue that I have vague memories of reading about. But, why would the threads be any different than on std bleeders? Maybe one particular brand had issues? I was looking at the Earl's bleeders...but geez, they're $20/pr!
- Street Cred : 71
Re: Speed Bleeders
The issue is when you lift off the brake, if the thread sealant isn't working, air will get sucked in through the threads. With a standard bleeder this isn't an issue, because it is tightened up before you let off the brake.
I suppose you could try to apply more sealant it becomes a problem. I have used the Russell and Doorman speed bleeders with no issues so far.
Re: Speed Bleeders
Mcarlo77.....years ago I had the same issue with a MityVac....didn't seem to achieve the results I wanted either. I too not wanting to grab a friend to help in the mundane job of "pumping and holding " the brakes.
Go online to the You Tube and several videos there of how to make your own one man brake bleeder....with a water bottle!
The amount of guys that have done this and then posted is mind boggling.
Watch two or three....or ten . Then cobble something together with ideas from each.
This is what I have done with all of my brake upgrades over the last 3 years. They seriously work !!!
impalamonte- G3GM Member
Re: Speed Bleeders
76 Malibu wrote:The issue is when you lift off the brake, if the thread sealant isn't working, air will get sucked in through the threads. With a standard bleeder this isn't an issue, because it is tightened up before you let off the brake.
I guess I still don't understand why the threads on the speed bleeders wouldn't be made to the same specs and perform just as well as on std bleeders? Afterall, they both are loosened and tightened during a bleed. Earl's does seem to have a better idea with the spring-loaded plunger to prevent air from entering even if it were to work it's way past the threads.
Always open to home remedies. I'll browse the YouTube videos as suggested and see what the home-made bleeders can do for me, too.
- Street Cred : 71
Re: Speed Bleeders
I put speed bleeders in all my cars and they have been great! PM sent
Also, if you put a hose on the bleeder and have it going upwards a few inches, then looping 180 degrees down and into a catch bottle. Every time you pump the pedal bubbles will come and rise to the top in that couple inches. But still keeping fluid close to the bleeder so air cant reenter.
Id throw a rebuild kit in the master if theres no rust in the bore. Easy job.
- Street Cred : 79
Re: Speed Bleeders
I use my old pickup for a vacuum source. I get enough vacuum tubing to go around the car and then just let the engine vacuum pull the fluid through. You wouldn't believe how quickly you can do a fluid flush with a steady 20 inches of vacuum vs. getting hand cramps on a mighty vac. No mess to clean up either.
» Fireplace ash as compost and 'speed' composting.
» Measuring arrow speed without a chrony?
» Telmex Internet Speed
» Tyre Safety Warning
» Understanding Electronics Part Three
» New Lineup LSH Cars added now and a new larger size available
» Cool YouTube Video
» Crate engine question
» this looks familiar
» Dealer brochures for sale
» 1975 Olds Cutlass
» Ebay alternative ????
