steering colum
+6
dade1989
Biomedtech
sick73chevelle
10 posters
steering colum
i was woundering if a 1972 chevelle steering colum would fit my 1975 laguna
dade1989- G3GM Member
Re: steering colum
Good question ! My '74 Malibu came with a non-tilt column, and I bought a tilt column off of Ebay, from a '73, which was actually slightly different, even though it's in the same generation. Hopefully someone here can answer your query.
Re: steering colum
i hope so cuz its easyer to find a needle in a hay stack then finding parts for my laguna s3 especially in miami
Re: steering colum
72 will not fit.
The only difference between a nontilt and a tilt is the wires going into the ignition switch. In all respect the wires are just turned upside down. One rod pulls up the other pushes down. The rod is on top, it moves when you turn the key.
Its hard to explain, cuz i dont have a non tilt to compare it to.(picture wise)
Re: steering colum
I can tell you that I installed a tilt column from a 73 Monte into a 72 monte and it was an exact fit, so I don't know why it wouldn't work the other way around. Both cars were floorshift if that makes any difference. There may be a slight variation somewhere on the column cosmetically. Maybe someone on this site might know what it is. I do know that tilt columns from 69-72 a-bodys seem to fetch more $ than 73-77's, for some reason.
sick73chevelle- G3GM Member
Re: steering colum
so from wat car and wat year would be the best for me to get a steering column that would fit my 1975 laguna s3
Re: steering colum
It will physically fit, but the arm that the linkage connects to in the engine bay is different.
Re: steering colum
It would be easier to adjust the linkage going between the column and trans.
To change the arm would require basically overhauling the column, and I'm not sure the internal specs are compatible.
Re: steering colum
Pretty much any other A Body from 73-77
i.e.
Olds Cutlass
Pontiac Lemans
Pontiac Grand Am
Pontiac Grand Prix
Buick Regal
Buick Lesabre (I Think thats an A body)
Chevy Malibu
Chevy Monte Carlo
Possibly the X and B-Bodies too although I can't verify since i don't have a Hollanders....
Anyone?
X - Bodies
Buick Apollo (1973–1974; 1975 sedan only)
Buick Skylark (1975 coupe only; 1976–1979)
Chevrolet Nova (1968–1979)
Oldsmobile Omega (1973–1979)
Pontiac Ventura (1971–1977)
Pontiac Phoenix (1977–1979)
i.e.
Olds Cutlass
Pontiac Lemans
Pontiac Grand Am
Pontiac Grand Prix
Buick Regal
Chevy Malibu
Chevy Monte Carlo
Anyone?
X - Bodies
Biomedtech- G3GM Member
Re: steering colum
What is wrong with your column in the first place?
Re: steering colum
i was moving so i let my little brother drive my car to the new place. the car turned off on him and he broke my ignition trying to start it so i know it wasent too smart but i destroyed the steering column to get the car started
Re: steering colum
Re: steering colum
I wonder if an 80s A/G body column would fit. I have one I need to get rid of to make more space. JB
Re: steering colum
Biomedtech wrote:Buick Lesabre (I Think thats an A body)
Actually that's a B body like the Impala/Caprice. I think you're looking for the Buick Century.
Re: steering colum
My Hollander Interchange isn't showing any other compatible steering columns outside the '73-'77 GM "A" bodies. I'd be glad to help you out, but they don't come cheap at the yards...unless the local U Pull would happen to get one in. Even harder to find a column with the key in it.
- Street Cred : 74
Re: steering colum
Can't someone make a key for a new column? Might want to ask a locksmith about it. An original 73-77 A body column would prob be your best bet but JB might be right- the 78-79 Malibu columns look very, very similar.
I might know of a green column from the 73 Monte I picked apart last summer- there was a key in it. I can call to see if they still have the car- can't remember if it was a tilt or not though. I was a column shift style.
Re: steering colum
I just compared a column from a '79 Monte to one I have from a '76 Century and they are VERY similar. However, the arm that connects to the linkage inside the engine bay is about 2" further down on the Century's column.
- Street Cred : 74
» '74 "SS" - Los Angeles
» AC compressor belt tension
» LS swap
» 75 el camino project.
» Help me find my Cutlass?
» '74 Laguna - Arizona
