question about puttting big block in g 3
hey i found a 454 at a good price but has no accessory brackets or pulley well any brackets or pulleys go from 350 to 454 trying not to spend a lot pf money to do change over but open to any ideas
the beast- G3GM Newbie
Re: question about puttting big block in g 3
go get the cheap chrome alternator brackets. You can use the same Small block alternator. AC big block pulleys are common, start calling local salvages saying that you need pulleys and powersteering brackets for a mid 70s chevy truck, when they ask the engine say, 454. If you call asking for big block chevy brackets they will laugh and say no and will do the same for chevelles with big blocks.
![question about puttting big block in g 3 SIG2](https://2img.net/h/i23.photobucket.com/albums/b357/greenchevelless/My%20Chevelle/SIG2.jpg)
BlackChevelleSS- Management
SBC brackets will not work on a BBC. You can make your own brackets if you got the skills.
I know you don't want to spend too much money, but this would be the way to go. All of the brackets plus switch to serpentine.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=NAL-19172806&N=700+115&autoview=sku
Kits include:
* Bolts, nuts, spacers, and brackets
* Water pump with pulley
* Crankshaft pulley
* Serpentine belt
* Alternator
* Drive belt tensioner assembly
* Power steering pulley
Add up the pricing for junkyard stuff plus a new alternator & water pump & you're not saving much money at all.
Kits include:
* Crankshaft pulley
* Serpentine belt
* Alternator
as of a few years ago, all the brackets were available new from GM- under $50 for PS and alternator brackets for an early 80's pickup.
novaderrik- G3GM Member
