Calling Wally!
Calling Wally!
Can an upholsterer re-web seat belts?
I found some swivel bucket belts. They're black and I need tan/buckskin. I've dyed the plastic parts, but the webbing just soaks it up.
Re: Calling Wally!
Roadcaptain S3 wrote:Can an upholsterer re-web seat belts?
Yes and no
If its a retractable seat belt I have pulled out the belt from the re-tractor as far as possible then clamped it with small needle nose vice grip. you have to lay the new tan belt over the old one and sew at least 1" over top of each other as close to the re-tractor end as possible for sewing machine. (A shoe repair place will be able to get the closest to the unit with shoe patch machine but I used a regular upholstery machine and it works) With this doubled up section it takes up space so you wont get as much belt into the re-tractor any more. So you may have to leave the tail coming out longer. As for the other end with the buckles not a problem to sew them up. My suggestion is if you find someone willing to do it then have him sew up the re-tractor side then install it pull it up use clamp on tail end to make sure you have enough belt. As you don't want the over lap section coming out of the plastic sleeve as its to fat to slide back in. You maybe able to tell by my reply that I have done this before. The guy had stock belts in different color but they came up to short to fasten. Had to have his seat all the way back to get latched.
So buy a roll of seat belt webbing so you have plenty. Here is good price for webbing. measure and get twice what you think you need just to be safe
http://www.ebay.com/itm/5yd-nylon-seat-belt-type-webbing-1-5in-choose-colors-American-made-free-ship-/141175654307?pt=LH_DefaultDomain_0&var=440246435869&hash=item20deb987a3
O and tell the Upholster that you will pay cash as the liability issue is so big most wont even touch it. Use nylon or Dacron thread NO Cotton thread for it. The Upholstery shop will have the thread.
Re: Calling Wally!
Thanks.
Kinda caught me off guard because I've dyed some belts before with no problem. Yesterday, the dye just shot right through with absolutely no change whatsoever.
I did find a service online that restores old seat belts, but there is an upholsterer right up the road. I'l try him first.
Re: Calling Wally!
Is there a way to dye the webbing? Like RIT or something?
Re: Calling Wally!
how about you just get some Tan / Buckskin belts then switch them to the swivel one from This Guy
Re: Calling Wally!
I've got the tan bench belts that I could use, but the webbing isn't that expensive.
Unless you have tan swivel belts?
Re: Calling Wally!
Whats your Floor mount look like and that will tell me which I have ?
Re: Calling Wally!
The bench base has a bolt on top for the seat to sit on, the bucket belts don't.
Re: Calling Wally!
If you've got tan straps already from your bench retractors, all you need to do is swap the webbing from from those to the swivel retractors. This is totally do-able as Dino (Dinomite) can attest as we've both been successful making the swap on front swivel belts. And, both of us are about to do the rears as well. You'll just need to know how to disassemble the spool to remove the webbing. Not particularly difficult...but, like anything else, just have to pay attention to details as you take them apart.
PM me for more info if you want.
Re: Calling Wally!
Mcarlo77 wrote:If you've got tan straps already from your bench retractors, all you need to do is swap the webbing from from those to the swivel retractors. Â This is totally do-able as Dino (Dinomite) can attest as we've both been successful making the swap on front swivel belts. Â And, both of us are about to do the rears as well. Â You'll just need to know how to disassemble the spool to remove the webbing. Â Not particularly difficult...but, like anything else, just have to pay attention to details as you take them apart.
Easy as pie.
Dinomyte- Donating Member
Re: Calling Wally!
Gracias fellas. Now I've got a couple of options at least.
Hope to start swapping later this week, I'll post progress.
» muffler choices
» '77 Cutlass 442- NoCal
