Calling Limey...shifter Q
I know your using the cutlass console, found a pic of it. Will the shifter work as well or do we need one from a chevelle or monte?
I THINK it should work, but it looks different, like it rides lower, closer to the trans hump
Re: Calling Limey...shifter Q
no it fits under there with a little wiggling and that was a HUrst Shifter in there as well, and since getting the SE I sold everything cutlass guy got a hella deal on it I might add, LOL
Cool. Thanks.
Trying to decide whether to use the olds console and shifter or the chevy. I agree with you that the olds is purdier and that little storage box is cool too!
If I still had the green car no question I would have used it IIRC It does block using the ashtray, but I don't smoke so no worries there.
I had a '77 cutlass console with a Hurst dual gate shifter. When I switched to a Chevy console, I used the rear bracket from a OE shifter (direct bolt on...holes were already on the Hurst ?!). I made a custom upper plate but it all fits. The lower deflector (trans tunnel on floor) needs to be removed to use the olds console, I don't remember a problem with the ashtray though.
Tthis was from a while back, but the cutlass console is in place.
Cool vid. Thanks
The olds console I'm looking at just has the curved stock handle. I think it'll bolt on the same as the monte/malibu shifter...right?
My car was originally a column shift, I never had a OE shifter installed so I can't answer that.
» 1974-1975 Chevelle Console Shifter plate/ SS Shifter Knob
» Well the old Limey is Sold & Introducing The New Limey
» Calling OldSchool454
» Dash Pad For Sale
» muffler choices
» '77 Cutlass 442- NoCal
