Spray adhesive for carpet recommendation
I installed carpeting about 5 years ago and it's still lumpy. I'm planning to pull out the seats anyway for a good dose of sound deadener on the floors and trunk area of my station wagon so I figured that would be a good time to get the carpet glued down and looking smooth. Any recommendations for adhesive to use?
dhw3971- Donating Member
Re: Spray adhesive for carpet recommendation
I've never heard of anyone gluing it down. I would assume spray adhesive wouldnt hold due to heat.
Yeah same here about never needing to glue it down. Does it have a jute backing? Do you have the asphalt backed sound deadener under the carpet?
3M makes an aerosol adhesive spray. Wouldn't use anything on just the carpet itself, could bleed through and ruin the carpet.
I know some people I have heard Put that sound deadener down and then Use 3M double sided carpet tape with good success
The carpet does not have jute backing---it's aftermarket and about 5 years old. The back side is covered with a clear plastic-type of surface.
The original asphalt-backed sound deadener was in bad shape and has been removed and replaced with newer aftermarket material...it's got foil on both sides and some type of fibrous inner layer.
Ahh plastic on foil! I'm surprised you haven't fallen out of it in a turn! Get some spray adhesive in an aerosol can, that'll make it stick somewhat to the foil underlay.
chevellelaguna wrote:Ahh plastic on foil! I'm surprised you haven't fallen out of it in a turn! Get some spray adhesive in an aerosol can, that'll make it stick somewhat to the foil underlay.
 No shizz, brother!  Add on the vinyl-covered bench seat and you've got one helluva carnival ride.
Yesterday at 5:02 pm by Matchstx
Yesterday at 4:56 pm by Matchstx
Yesterday at 2:48 pm by Limey SE
» Window louvers
Yesterday at 12:47 pm by JCervantes10
» 1973 Chevelle SS 1 Family
