Th350 skipping 2nd
2 posters
Th350 skipping 2nd
Got a new surprise with the car today noticed that I end up going straight from 1 to 3 Can hit all ranges manually pushing it through. I’ve checked governor, vacuum line, and modulator all which don’t seem to be the issue so not sure if it’s a sprag or what I’m not very well versed with this tranny yet hoping someone has a better idea of what’s going on than I do. Also no excess noise while shifting. Fluid level is also good and cable adjustment is good...
Tree80Tree- G3GM Newbie
Re: Th350 skipping 2nd
pull the pan you will probably find the sprag in it.
TrendSetter- G3GM Newbie
» 77 LEMANS
» Pre Bent Fuel Line
