'75 Malibu seatbelt retractor
Hey, looking for help..I've got a '75 Chevelle/Malibu with a stuck seatbelt retractor (in retracted position) that I cannot get to release..An further complications of the T-50 hold down bolt frozen..Any insight on freeing the bolt as well as the seatbelt retractor would be greatly appreciated...Can the seatbelt retractor be rebuilt upon removal from floor?
Doc75- G3GM Newbie
Re: '75 Malibu seatbelt retractor
I've taken apart, cleaned and reassembled a number of retractors and your problem is most likely either the strap is twisted inside the retractor...or, the internal metal bar that allows the belt mechanism to release is rusted and seized. So, yes...it can be fixed once it's removed from the car. That brings up the other problem as you've already discovered...and, that is how to remove a seized T50 bolt. I don't have an easy answer for that. Living here in the Rust Belt, I've had to deal with this often when salvaging belts from the JY's. Unfortunately, I often cannot even break them loose with my Dewalt impact wrench. And, I've broken my share of bits trying.
Guys at the JY's will get out the acetylene torch and put heat to them from underneath to loosen them. Maybe you could find a shop that could help you out with that?
I've used this tool from Eastwood to remove the tailgate bolts from several el caminos without any issues. They are typically very hard to remove and used torches in the past with good results as well. I'm thinking these would be a good options in your situation as well.
https://www.eastwood.com/eastwood-screw-buster.html
- Street Cred : 33
» muffler choices
» Dash Pad For Sale
» '77 Cutlass 442- NoCal
» Dash woodgrain
