Center Console hinge needed
Re: Center Console hinge needed
The Parts Place sells replacement hinge/box assembly. Just remove your upper pad and reattach to new unit.
I trust you are OK. Very sorry about the rear axle failure.
76Chevelle2Tone- G3GM Member
Mcarlo77 wrote:The Parts Place sells replacement hinge/box assembly. Just remove your upper pad and reattach to new unit.
Thank you - I'll take a look.
[Edit - it's on it's way!]
K
Keith Seymore- G3GM Member
76Chevelle2Tone wrote:I trust you are OK. Very sorry about the rear axle failure.
Yes - I'm "fine".
It put the kabosh on my race season so far. We've also moved from Detroit to closer to Lansing and I was hoping to keep to the race schedule even with the move, which probably would have worked if everything had stayed together.
I crushed the ring and pinion right at the launch (3rd pass of the season, in Rockingham, and 3rd pass on that unit). Didn't even make it 60 feet. I leave the console lid open because the temp gage and engine cooling fan switch are located inside; I must have pitched forward under decel and bumped the cover ripping it right off.
Next event is mid July in Martin Michigan, so I have some time to get my act together.
K
Keith
What is the issue with your dash?
Keith Joe73 has an Oldsmobile Posi unit that maybe could scavenge parts needed till you get what really needed he's in NY
76Chevelle2Tone wrote:Keith
Got cracked during the roll cage install.
Limey SE wrote:Keith Joe73 has an Oldsmobile Posi unit that maybe could scavenge parts needed till you get what really needed he's in NY
TY -
K
Keith Seymore wrote:76Chevelle2Tone wrote:Keith
Keith that looks narrow enough for Sugru to work easily for it. You can find Sugru on Amazon. The great thing about it is that it doesn't dry out ever and stretches and contracts without breaking or splitting. Once inserted it can be painted/stained. I have used it successfully on the dash and on wooden furniture hairline cracks where nothing else worked. It is not expensive ~$20. Since your dash is black it makes color matching even with Sugru easy, but an exact match usually requires a staining agent of some kind.
76Chevelle2Tone wrote:Keith Seymore wrote:76Chevelle2Tone wrote:Keith
Excellent; thank you. That is exactly the kind of input I was looking for.
K
Olds rear has been sold. Ad has been taken down. Thanks
Limey SE likes this post
» center console
» Center Console from previous gen
» what are the factory correct fasteners for center console, 4 speed insert, and glove box insert?
