lost ignition key and steering is locked
+6
maliburacinfreak
10 posters
I was planning on new lock cylinders anyway,how do I unlock the steering on a 73 malibu with no key? Thanks for yet another bailout!
fishhead- G3GM Member
Re: lost ignition key and steering is locked
Theres a pin that has to be depressed. You can see it when the wheel is off. 11:00 position. It moves with ignition.
1973montec- Donating Member
there really is no way to unlock it unless you want to take the column apart and take out the cylinder.the lock pin as chris mention is controlled by the cylinder.
And FWIW, that pin is made of magnesium, so don't grind on it.
Nope..no grinding.No sledgehammers either...
what happened next?
did you get it apart?
Just now got a steering wheel puller and new ignition lock cylinder.I hope to get to it today.Many,many irons in the fire but its a beautiful weekend here in Bama.All I have is a smartphone so I havent posted pics yet but will hopefully learn how soon.Thanks for asking,I'll update here soon.
Heres a pdf I found somewhere, I'd like to credit where its due but I cant remember where i got it...
Great description on how to disassemble a tilt column, but its all the same down to the lock cylinder.
http://www.filedropper.com/tiltcolumndr1rev09ja2010
Biomedtech- G3GM Member
just pull the lock plate with a lock plate remover and then reinstall the steering wheel temporarly if you just need to move it. Dont drive it that way tho.
BlackChevelleSS- Management
You can buy a lock plate removal tool? And, all this time I've been wrestling with manually compressing that plate spring in order to work the round clip out of the groove. Where can a person buy said tool?
Mcarlo77 wrote:You can buy a lock plate removal tool? And, all this time I've been wrestling with manually compressing that plate spring in order to work the round clip out of the groove. Where can a person buy said tool?
http://www.zip-corvette.com/ProductDetails/ProductDetails.aspx?pid=%7B35516c4a-ad7d-45b9-83b8-fd3bc2a15c7e%7D&gid=%7Ba61d7b36-c954-460a-be3d-cfcaf0a2dc76%7D&GroupName=Tools&pname=Steering+Column+Upper+Lock+Plate+Removal+Tool&Referer=&Alias=&ptct=GL2-SR&CTitle=
i bought mine at advance auto
Well, I'll be a *#&%@*... won't have to unleash my repertoire of swear words next time I have to tackle that procedure!
Mcarlo77 wrote:Well, I'll be a *#&%@*... won't have to unleash my repertoire of swear words next time I have to tackle that procedure!
its works really good. ive had one for about 30 years.but with the move and all,i couldnt seem to find it. so i had to buy a new one.
Do I need to remove that little hex head screw that is located about 1"-1 1/2" below the lock cylinder behind the cam assembly? I pressed/lifted/molested the little recessed flat lever inside there and no release.All thats left is that little screw...is that whats holding the cylinder in place? Thanks.
Harbor Freight has em too for 29.99...
http://www.harborfreight.com/steering-wheel-remover-set-68982.html
Haw! I have a Grant custom steering wheel so I didnt need any special tools and I have everything off down to the turn signal cancelling cam.I have the cam assembly pulled out just enough to get access to that little hex head screw.Do I need to loosen/remove that screw to pull the ignition key lock cylinder out? Is that what is holding the cylinder in place? I've come this far and need advice on this last step.Thanks fellas.
yes, pull that screw and the cylinder slides right out
maliburacinfreak- Donating Member
our columns have a little black thinggy you push in.
78-88 columns have a screw you have to take out.
chris help me out here.
Shucks....I'm grasping at straws here.I've tried eveything to release the lock cylinder and no luck.It seems my only option is to cut the wires on the turn signal cam and dig deeper into the steering column.What the hell does it take to get that thing out?
It could be that the cylinder has never been replaced before and the access hole is covered over with casting flash.
That slot they have the screw driver in will be covered over with a thin layer of casting flash if the cylinder has never been changed before. It breaks out easily and then you will be in business.
The below description is straight from the PDF I posted a link to earlier.
Removing Lock Cylinder - Description #3
When removing the lock cylinder from the column, most shop manuals recommend
inserting the ignition key and turning the lock cylinder to the RUN position. However,
the lock cylinder can also be removed without the ignition key being inserted. Either way
will prevent damage to the key warning buzzer switch.
The 1969 thru 1976 lock cylinders are held in place by a metal spring tab that sticks out
of the lock cylinder. This tab engages a narrow, rectangular slot in the column housing.
Looking straight into the column housing, this slot is vertical, right on the centerline of
the lock cylinder, and located 1.75 inches from the underside of the chrome wings on the
lock cylinder. See picture on next page.
If your steering column has never had the lock cylinder replaced, there will be a thin die
casting metal membrane covering the slot. Keeping a thin bladed tool to the right side of
the slot, break the housing flash. Now depress the spring tab. Also I have found that if
you don't push the spring tab pretty much in the center it will not release the lock cylinder
because it tends to rock side to side.
Good God-A-Mighty,it's things like this that make me quote Nancy Kerrigan..."WHYYYYYYYY???" Thanks man,I owe you one!
Dont cut the wire. Take off the bracket that is under the column, it will give you more movement to bring up the cancel thingy.
Need to take off the 2-9/16 nuts than the 4- 1/2 screws. The column will drop a little , but its gets the cancel thing out of the way
» Dash Pad For Sale
» muffler choices
» '77 Cutlass 442- NoCal
