How To Disassemble/Repair Strg Column
How To Disassemble/Repair Strg Column Empty How To Disassemble/Repair Strg Column
Post by Mcarlo77 Sat Feb 07, 2015 2:09 pm
Found this on another site and thought it was an excellent tutorial on how to work on our gen of tilt strg columns.
Kudos to Mr. George Nenadovich for putting this together
http://www.buickperformanceclub.com/tiltsteeringcolumnwobble.htm
How To Disassemble/Repair Strg Column Empty Re: How To Disassemble/Repair Strg Column
Post by pila Sat Feb 07, 2015 4:11 pm
That's a good tutorial ! Thanks for the link !!
I had to get into the column on a Chevy van I had, to fix the wobble.
Currently I need to take the column apart on my '74 Malibu. The spring the pushes the column up, when it's released with the lever, must be broke. I have to push it up manually, and it's stiff even then. It needs help for sure.....and maybe I'll pull it all the way out & change bearings etc.
Bill
Post by Wallyuph Sun Feb 08, 2015 4:38 pm
Mcarlo77 wrote:Found this on another site and thought it was an excellent tutorial on how to work on our gen of tilt strg columns.
Thank you for posting Steve
Post by Limey SE Sun Feb 08, 2015 6:29 pm
Steve you have been stickyfied Will be a lot easier to find now
Post by pila Sun Feb 08, 2015 9:27 pm
Good to hear it's a sticky. Smile
