swap gears?
Landonus
rebel101150
Graham Perkins
Page 1 of 2
swap gears?
General question for you experienced forum members. My chevelle has 3.08 gears it looks like and I know it's holding the car back quite a bit. How hard would it be to swap them out and what's the highest I could go to? I'm going to be pushing my 350 to about 350 horsepower soon so I want her quick as possible.
rebel101150- G3GM Member
Re: swap gears?
You have to know what you are doing to set up a rearend. It requires special tools and ability. Most guys sent setting up rearends and transmissions to the pros. As for what gears thats up to you 411's will get you up and moving in a hurry but you will run out of steam at about 55 mph. I have 373's and they limit top speed somewhat also. 342's would be a good compromise. It all depends what you want.
Re: swap gears?
dynchel wrote:You have to know what you are doing to set up a rearend. It requires special tools and ability. Most guys sent setting up rearends and transmissions to the pros. As for what gears thats up to you 411's will get you up and moving in a hurry but you will run out of steam at about 55 mph. I have 373's and they limit top speed somewhat also. 342's would be a good compromise. It all depends what you want.![]()
well i'd be paying my local guy to do it. Whatever I can't do I have him do usually. 373 sounds like a decent option then. Any place you know of where I can I get some? online places. these 3.08's are just awful
Re: swap gears?
Might want to look into transmissions. Is yours auto or standard shift? I had an M22 with 342's in a 75' Nova with a 350 .60 and it would run 3,600 rpm at 80 mph in 4th gear. It's the best set up I could find for daily driving mpg wise and still having a bit of kick. It's the only time I messed with the gear ratio in any of my cars. I remember doing a lot of homework and asking a lot of people. Wish I hadn't shed it but I have my G3 to thank for it.
Landonus- Donating Member
Re: swap gears?
Also, I'll check the Laguna tomorrow and see what the gears are. I HIGHLY doubt it's a posi but if it is I'll be keeping it.
Re: swap gears?
Landonus wrote:Might want to look into transmissions. Is yours auto or standard shift? I had an M22 with 342's in a 75' Nova with a 350 .60 and it would run 3,600 rpm at 80 mph in 4th gear. It's the best set up I could find for daily driving mpg wise and still having a bit of kick. It's the only time I messed with the gear ratio in any of my cars. I remember doing a lot of homework and asking a lot of people. Wish I hadn't shed it but I have my G3 to thank for it.
apparently my message didnt post. well I unfortunately have an auto, wish it was a standard. I work from home so i'm not really worried about mpg, if i'm gonna go somewhere I wanna have fun doing it. I just want the fastest acceleration and don't wanna fall on my face, because right now shes losing steam at 35 she stops accelerating as quickly
Re: swap gears?
What trans are you running? If you have a 3 speed like a th 350 or 400 you don't want to go as low as a 411 or a 373 gear set for the street stick with the 342 like dynchel recomended. If you are running a later model overdrive trans a 373 would be good. I am running a 373 in my 76 with a th350 and a 454 and it is no fun on the highway.
Thanks Graham
Thanks Graham
Graham Perkins- G3GM Member
Re: swap gears?
What is your MPH-RPM ratio Grahm? Is it a stock 454?
Re: swap gears?
my specs are a L65 350, TH350, 8.5" 10 bolt, 3.08 gears, factory limited slip diffferential
what would be my best for that
Re: swap gears?
One good way to go is using a 2004R. That OD trans with a 3.73 rear gear is the best of both worlds. Lots of folks in the El Camino group have went that way.
Re: swap gears?
pila wrote:One good way to go is using a 2004R. That OD trans with a 3.73 rear gear is the best of both worlds. Lots of folks in the El Camino group have went that way.
eh not really looking for a new tranny right now, just bought a house, the wife would kill me for spending money on that. just adjusting gearing, i can convince her thats necessary.
Re: swap gears?
The 3.73 would work fine, but of course gas mileage would drop some.
Re: swap gears?
pila wrote:The 3.73 would work fine, but of course gas mileage would drop some.
Okay, now where would I lose steam though. Trying to get my 0-60 under 10 right now
Re: swap gears?
Are you sure the gears are your problem? You should not be running out of steam at 35 mph with 308 gears.
Re: swap gears?
she only has 39k miles, i just notice a dramatic slowdown then. Im sure she needs a tune but everything is fine. Ive driven is all the way up, no slippage or anything up to 75. but it also has the original carb so that may be an issue too
Re: swap gears?
rebel101150 wrote:she only has 39k miles, i just notice a dramatic slowdown then. Im sure she needs a tune but everything is fine. Ive driven is all the way up, no slippage or anything up to 75. but it also has the original carb so that may be an issue too
on another note isnt the 0-60 qouted at 11 seconds or so for this car? seems about right
Re: swap gears?
Have you done a tune up since you had it? New plugs, wires, oil change, distributor parts? That and carb work might help out a lot.
Re: swap gears?
Landonus wrote:Have you done a tune up since you had it? New plugs, wires, oil change, distributor parts? That and carb work might help out a lot.
a friend did, what kind of time should I be getting? maybe it wasnt done correctly. Had a friend do it, I work too much to handle small stuff usually.
Re: swap gears?
I have 373 gears with a th350 trans. It's alot of fun around town, on the freeway I'm limited to about 65/70 mph. I bought my gears from the jegs catalog, summit racing is also a good place. As for factory times I have no idea. My car was modified when I got it and it was certainly no slouch. You might want to get your engine running properly first before selecting gears. Just my 2cents.
Re: swap gears?
I'm no mechanic but any time I get a new car I always replace the plugs, wires, distributor cap, rotor button, thermostat, clean the carburetor and do an oil change. I find that it helps when troubleshooting to know what's new. As for your time I have no clue as I've never timed myself but surely one of the veterans here can answer that. As for your tune up, to not have been done correctly your friend would have to be mighty incompetent. Do you know what all he replaced? Do you know if it was like this before he worked on it?
Re: swap gears?
dynchel wrote:I have 373 gears with a th350 trans. It's alot of fun around town, on the freeway I'm limited to about 65/70 mph. I bought my gears from the jegs catalog, summit racing is also a good place. As for factory times I have no idea. My car was modified when I got it and it was certainly no slouch. You might want to get your engine running properly first before selecting gears. Just my 2cents.![]()
Ill definitely make sure its in line first, he tends to slouch himself but did it for free so i couldnt complain. i'll do it myself and then i'll figure out a gear. i'm thinking 373 but i don't want to be limited to 70...i kinda live on back roads and even my honda does 90 back here most of the time. cops basically don't exist, your worst worry is a deer. If a cop flips on his lights, well just keep going. they tend to back off. really country out here
Re: swap gears?
Landonus wrote:I'm no mechanic but any time I get a new car I always replace the plugs, wires, distributor cap, rotor button, thermostat, clean the carburetor and do an oil change. I find that it helps when troubleshooting to know what's new. As for your time I have no clue as I've never timed myself but surely one of the veterans here can answer that. As for your tune up, to not have been done correctly your friend would have to be mighty incompetent. Do you know what all he replaced? Do you know if it was like this before he worked on it?
He picked it up, I hardly drove it pre tune.it sat 25 years I didn't trust it, hell it still has the original balding tires. he said he did all of that and tuned the carb, but i'm doubtful. I'm still trying to figure out the best carb replacement for this one for performance.
Re: swap gears?
rebel101150 wrote:dynchel wrote:I have 373 gears with a th350 trans. It's alot of fun around town, on the freeway I'm limited to about 65/70 mph. I bought my gears from the jegs catalog, summit racing is also a good place. As for factory times I have no idea. My car was modified when I got it and it was certainly no slouch. You might want to get your engine running properly first before selecting gears. Just my 2cents.![]()
Careful attacking those corners, your G3 will weigh at least 1,500 lbs more than your Honda.
Re: swap gears?
'Landonus wrote:rebel101150 wrote:dynchel wrote:I have 373 gears with a th350 trans. It's alot of fun around town, on the freeway I'm limited to about 65/70 mph. I bought my gears from the jegs catalog, summit racing is also a good place. As for factory times I have no idea. My car was modified when I got it and it was certainly no slouch. You might want to get your engine running properly first before selecting gears. Just my 2cents.![]()
good advice.
Re: swap gears?
Hi,
To answer landonus question, the 454 isn't anything crazy it has a cam ,headers, holley 750 double pumper, performer intake. The speedo doesn't work but keeping up with traffic on the hwy the tack is around 2800-2900 rpm. Oh by the way I need the cruise control box that sits on the lhs inner fender to get my speedo working if anyone has one for sale.
Thanks Graham
Thanks Graham
Page 1 of 2
» AC compressor belt tension
» '74 "SS" - Los Angeles
» LS swap
» 75 el camino project.
» Help me find my Cutlass?
» '74 Laguna - Arizona
